I'll try to make this concise: My speedo has had an intermittent issue for a while now. It will bounce around and usually stick around 20mph or so when cruising on the highway. I never FELT the power steering effects associated with this, however. I purchased an entire instrument cluster from a 'trusted' member here and installed it last night. Well, to no avail, the speedo was stuck on 0 - wouldn't budge. I kept driving to see if it would wake up, and it did, but then returned back to 0. While driving to work this morning on the highway, I almost died. The steering took a mind of its own, luckily I was holding the steering wheel tightly. QUESTION: What items are related in this system? I know there's the speed sensor and the speedometer itself. Anything else that could be effecting these, or are they BOTH bad? I'm trying to avoid any (fatal) accidents. ThankZ!!
Speedometer and Power Steering - Scary - FrozTTy07:11:16 01/24/18
